Centralny raz jeszcze (reaguje tylko kierunkami) błedy
16. central doorlocking system motor voltage low
Short to ground in circuit to control unit terminal 7 (12P), 8 (12P), 10 (28P)
The trouble code is stored if the fault is recognised for 3 times.
Effect:
If a fault is recognised the over load switch is activated (the control of the motors is deactivated for 30 s, only one unlock function can be realised)
47. central door locking motor supply voltage low - intermittent
Ignition key in ignition lock position I/II/III
The voltage at the control unit input (terminal 9 (12P) ) is too low.
The trouble code is stored after ignition key in ignition lock position I/II/III is recognised for 2 times.
Recovery Condition:
The trouble code will be deleted, if ignition key in ignition lock position I/II/III is recognised for at least 16 times without fault.
Concerned Terminals:
9 (12P)
I pare pytań jesli ktos to rozgrzebywał bardziej.
moduł centralnego jest w nogach pasazera a odbiornik pilota gdzie sie znajduje ??
kierunki czasami reaguja a alarm centralny padł sobie jadac ze zlotu do domu.
[ wiadomość edytowana przez: homer171 dnia 2008-09-21 19:52:11 ]
[ wiadomość edytowana przez: homer171 dnia 2008-09-21 19:53:02 ]
