MARCELBIALOGARD BIAŁOGARD | 2005-01-10 17:33:03 WITAM. MAM PROBLEM Z PRAWĄ SZYBĄ, OTWIERA I ZAMYKA SIĘ PUNKTOWO, A CZASAMI MUSZĘ OTWORZYĆ A NASTĘPNIE ZAMKNĄĆ DRZWI BY JĄ ZAMKNĄĆ. |
maartiness BMW E-36 COUPE kalisz | 2005-01-18 16:04:34 WITAM. MIAŁEM PODOBNY PROBLEM TYLKO ŻE Z LEWA SZYBA NIE WIEM KTÓRY MASZ ROK TEJ "KUPAJKI" ALE JA MAM 95 I U MNIE JEST TAKI SYSTEM ŻE PRZY DOMYKANIU SZYB JAK PODŁOŻYSZ RĘKE ONA DOTYKA JEJ I WRACA NIE ZAMYKAJĄC SIE I PROBLEMEM U MNIE BYŁ BRUD NA PROWADNICY SZYBY GDZIE MUSIAŁEM ROZKRECIC TAPICERKE I GO USUNĄC BO COFAŁO SZYBE I MOGLEM JĄ TYLKO DOMKNĄC KLIKAJA NA PRZYCISK DOMYKANIA SZYB KRÓTKIMI RUCHAMI ALBO SPRÓBUJ JESZCZE NACISNĄC MOCNIEJ PRZYCISK BO ONE SA DWUSTOPNIOWE I PRZY MOCNIEJSZYM NACIŚNIĘCIU SZYBA IDZIE SAMA DO GÓRY BĄDŹ NA DÓŁ JEŻELI U CIEBIE SIE TAK NJIE DZIEJE WYMIEŃ PRZYCISK- UZYWANY KOSZTUJE OKOŁO 15-20 ZŁ. POZDRAWIAM. MARCIN |
