kielkac | 2004-11-08 13:07:57 kabel od cewki albo od sterownika, ktory "niesie" informacje o obrotach... nie wiem niestety, ktorym pinem wchodzi on do zegarow, ale przejzyj schematy elektryczne... |
jarn LOB SYMPATYK Omega MV6 Białystok | 2004-11-08 13:14:06 Alternator? |
jacekn Opel Omega B Olesnica | 2004-11-08 14:20:24 Witam,
Schematu licznika nie mam ale łatwo dojść w ten sposób jeśli masz sterownik Simtec 56.1: schemat elektroniki Simtec 56.1 styki na złączu ECU: 1. Signal from knock sensor 2. Ground to crankshaft sensor/camshaft sensor 3. Oscillation signal to the crankshaft sensor 4. Oscillation signal to the camshaft sensor 5. Signal from coolant temperature sensor 6. Signal from air temperature sensor 7. Power supply to lambda sensor 8. Ground to air mass mater 9. Ground from chassis 10. Gearbox engagement signal 11. Load signal from automatic gear 12. Signal from air conditioning compressor 13. Diagnosis 14. Fuel consumption signal to boardcomputer 15. Control signal to fuel pump relay 16. Control signal to main relay 17. Control signal to tank ventilation valve 18. Constant power supply from battery 19. Ground from chassis 20. Signal from knock sensor 21. Signal from crankshaft sensor 22. Signal from camshaft sensor 23. Not connected 24. Ground from chassis 25. Signal from lambda sensor 26. Signal from throttle potentiometer 27. Signal from air mass meter 28. Ground from chassis 29. Signal from speedometer 30. Gear position information from automatic gear 31. Status signal from air conditioning system 32. Engine speed signal to revolution counter 33. Temperature switch, relay box (Omega-B only) 34. Power supply to throttle potentiometer 35. Engine control lamp 36. Control signal to lambda sensor pre-heater 37. Power supply from ain relay 38. Control signal to ignition amplifier, cylinder 2 & 3 39. Not connected 40. Control signal to ignition amplifier, cylinder 1 & 4 41. Ground from chassis 42. Control signal to EGR-valve 43. Not connected 44. Control signal to secondary air injection 45. Not connected 46. Power supply from main relay 47. Power from ignition switch (Terminal 15) 48. Control signal to injeciton valve, cylinder 4 49. Control signal to injeciton valve, cylinder 2 50. Control signal to injeciton valve, cylinder 1 51. Control signal to injeciton valve, cylinder 3 52. Control signal to idle speed correction valve 53. Control signal to the air conditioning compressor relay 54. Not connected 55. Diagnosis Powyższe nie dotyczy Simtec 56.5. Pozdrawiam, Jacek |
Prowo LOB WETERAN ![]() Kura Indian ze wsi (OPO) | 2004-11-08 14:20:49 Na złączu pin 22 - zielony(?) przewód.
(kilka miesięcy temu też go szukałem, co prawda w innym celu Schematy kiepskiej jakości wysłałem do Urg'a celem wrzucenia na ftp / stronę w późniejszym terminie. Zawsze coś tam na nich można zobaczyć. PS. Oczywiścia mowa o złączu pod zegarami. ----------------- Benzinový 3,6litrový vidlicový šestiválec [ wiadomość edytowana przez: Prowo dnia 2004-11-08 14:22:12 ] |
RP77 Opel Omega B Ostrołęka | 2004-11-08 14:42:02 Dzięki panowie za informację. Biorę narzędzia i zabieram się do roboty PS. Mam nadzieję że się uda |
Filipo X25XE + X30XE Poznań | 2004-11-09 00:56:32 Wczoraj zauwazylem, ze jak silnik jest zimny, a na dworze zimno i wilgotno, to obrotka sie zawiesza np na 2000rmp, 1200... Zawiesza sie tylko jak obroty spadaja. Rusza dopiero jak mocno sie przyspiesza (dostaje mocniejsze impulsy?). Jak silnik sie rozgrzeje to jest juz si. Wilgoc? Czy co jest tego przyczyną? Jakies pomysly? A moze cos juz odchodzi na tamten swiat? [ wiadomość edytowana przez: Filipo dnia 2004-11-09 00:57:01 ] |
RP77 Opel Omega B Ostrołęka | 2004-11-09 08:01:05 Mam nadzieję że się uda
Przy dokładnych wczorajszych oględzinach wyszło, że oprócz obrotomierz nie działa wskaźnik paliwa i kontrolka rezerwy Czy to oznacza że mam szukać nowych "zegarów"?? |
ilku LOB MEMBER Omega B234 Koszalin | 2004-11-09 20:16:01 witam
możesz sprawdzić miernikiem czy do tych wskaźników dochodzi masa. Sprawdż również regulator napięcia - taki mały sześcianik z trzema nużkami z tyłu w zegarach (na folii ze ścieżkami) powodzenia |
