SPRAWA WYGLADA TAK ODKAD KUPILEM ESIEGO (XR3I 1.
WIATRAK SIE NIEZALACZAL, OCZYWISCIE WSZYSTKO CO NIECHODZI W ELEKRYCE ZACZYNA SIE OD SKRZYNKI Z BEZBIECZNIKAMI I TAK BYLO .ELEKTRYKE ZROBILEM ,GDY ZLACZE NA KROTKO PINY OD KOSTKI KTORA WCHODZI W CZUJNIK TEMP ,WIATRAK SIE ZALANCZA ALE NORMALNIE NIECHODZI WSTAWILEM NOWY CZUJNIK OKAZALO SIE ZE I STARY I NOWY JEST DOBRY.CZY TO MOZE BYC WINA TERMOSTATU ?
SAMOCHOD SIE NIE GRZEJE CHYBA ZE STOJE W KORKU TO WLACZE CIEPLY NAWIEM NA DRUGI STOPIEN I JEST OK.
DODAM ZE USZCZELAK POD GLAWICA WYKLUCZAM NIELECA ZADNE BABELKI Z ZBIORNIKA WYROWNAWCZEGO NIE UBYWA WODY I NIE KOPCI NA SZARO .
PROSZE O POMOC BO NIC KONKRETNEGO NA FORUM NIEZNALAZLEM
