Italy Frosolone | 2009-09-16 17:21:06 nanoplex
nanoplex colours about the coil(cewka):1(-) from pin number 7,15(+) from ignition switch. The colours:b=white,c=black,f=violet,k=red,n=blue,p=orange, t=green (I hope there are no pices of mistake) the nanoplex manual |
Italy Frosolone | 2009-10-09 20:34:52 Mybe it can explains better:
3d Here, how to check the ignition. It's in polish and still to upgrde. However I'll add the link using google translate: check up On 126 nanoplex used were med210-211a with idle at 4° till april 13 1995 car n37077822 then med 213a wit idle at 10°: nanoplex on 126s On cinquecento 700 med 210a was used on weber-fos crburated ones while med 211a on aisan carburated ones: on cc There's a nanoplex replacement by ape: ape 20ff I can't add a comment or a piece of advice. Something about ape 20ff found on web,motonews too: ape promoter Here somebody says to have bought it: ape testimonials It doesn't to use google translate: tuning with ape |
Italy Frosolone | 2009-10-10 18:23:06 I missed allow,sorry. I was going to say: it doen't allow to use goole translate.
Nanoplex 210-211 and 213 ignition curves: curves There are 2 ignition maps in the nanoplex according manifold pressure: Vacuum in the manifold > 150mmHg the pressure sensor swicthes on and the pin 3 is grounded and it's selected the curve with more max advance. Vacuum < 150mmHg the pressure sensor switches off and it's selected the curve with less max advanve. I hope there are no mistakes. There's a bolt on the bottom of pressure sensor so it makes pressure adjustable. Would somebody be so kind to give a piece of advice about a good ignition for 126 maluch:parts,building.. Here something about polonez ignition module gl 1280-200,digitech,sts-12,str-12,kjs,rc: maluch ignition Can nanoplex rpm limiter be excluded? Thanks in advance |
Italy Frosolone | 2009-10-26 01:11:30 I found another nanoplex replacement. I don't know the difference.
It's called gl 226 and it's made by Obrem-Elektonika. ignition module gl 226 I ignition module gl 226 II Pozdravim/bye |
